  • Configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
  • Create the C-VLANs and add slots/ports.
  • Enable IP Multicast over Fabric Connect globally.
Use this procedure to configure the VRF timeout value. The timeout value ages out the sender when there is no multicast stream on the VRF. The default is 210 seconds.
You can use this procedure for Layer 3 VSN with IP Multicast over Fabric Connect services and IP Multicast over Fabric Connect for IP Shortcuts.
  1. In the navigation pane, expand Configuration > IP
  2. Select IP-MVPN.
  3. Select the MVPN tab.
  4. In the row for the appropriate VRF, type a value in FwdCacheTimeout.
  5. Select Apply.
